Lambda sensor
Wooju
Hello,
My Citigo failed the MOT today due to high emissions.
CO limit 0.2 mine is 0.9
Lambda limit 0.97 - 1.03 mine showed 1.23
I assusme lambda sensor is the one to be blmamed. I connected vcds and showed no errors.
I know some values can be checked using vcds. Could somebody suggest how to do it and what values are correct?
Thank you in advace
Peter
The sensors are probably fine. Your engine is either running a little rich or is burning oil, or the catalyst is below par.
Sometimes taking the car on a long high-speed run can help the catalyst. As Gyp says, a cleaner may work sometimes too.
Hello,
Appologies for a late reply.
Thank you gents for your feedback. Car did pass the mot after the long journey and making it really hot...
I will keep this in mind for the next year.
