Rapid Spaceback BT module failed/changed
Hi All
Had the unfortunate incident of my BT bluetooth module failing - Tried manual reset etc and it simply couldn't connect to any phones or be visible.
Picked up a replacement module of Ebay which was said to be Working - Only difference is original is K revision this one is J - Switched it over after taking out drivers seat and it connected straight away to mobile however it doesn't play audio from caller (Mic apparently works) Tried on a few phones and same problem - Other than trying a K revision is the anything obvious I should be trying?
