Fan has stopped working - Octavia vRS
Hi All,
My fan has stopped working. It is a 2001 Vrs. What should i check to see where prop lies. Where is fan switch located?
SB :finger::D
Cooling fan I assume????
Does the a/c cooling fan still work?
The aircon still works aok> Cheers sb
I just checked. Both fans work w the aircon on. I presume the fan on the right is aircon? The rad fan is no longer comming on on its own though and is only spinning w aircon on.
Cheers sb
The radiator fan failing is a "known" VAG fault, at least here in Trinidad. The Skoda dealer and the VW dealer buy the replacement fans from each other when they run out of stock, as it is a frequently failing part.
When it fails, the fan only runs at low speed or not at all, with the high speed not engaging. I never noticed it as I drive the car mainly with the A/C on and the extra A/C fan keeps everything within limits.
Also, with the fan failed, the fan does not stay on for a few minutes when you switch off the engine after driving the car hard.
