Skoda Rapid Sports 2017 Clock Alteration
I'm having a problem setting my Skoda Rapid 2017 Reg clock to new time since clocks went forward.
I can set it ok
But after I turn off the engine the clock resets back to the old time
I set clock as follows
Turn on Ignition
Press and hold 0.0/SET
Wait till CLOCK appears
Press 0.0/SET
Set Hour
Wait till Minutes appears
Leave as is
Wait till Screen changes
This sets the time one hour ahead
And it sticks at this
However as I mentioned above
After turning off and removing key it reverts back one hour
What am I doing wrong
1 hour ago, Kostas123 said:
The clock in the dash updates with the radio, perhaps your radio time is not set correctly?
When I change the time following the sequence in my original post the time shows up with the new time on my radio too
Is your radio touchscreen? I'd imagine all radios from MY2016 are touchscreen. Can you go into its settings and enable summer/daylight-saving time?
If your radio has GPS, then it's probably syncing the clock with satellites but it doesn't know that the timezone has changed...
Edited by Kostas123
