New member here. Paul.
Hi all just joined the forum.
Paul
I replaced my rear brakes at the weekend and can't find any. Information about the bleeding sequence, would anyone know,
It's on a MK2 superb 16tdi.
Thanks in advance.
In general, the advice is to start bleeding the brake furthest way from the master cylinder, and gradually work closer.
Thank you Ken.
Wasn't sure with having abs.
16 hours ago, Bluepaul said:
Thank you Ken.
Get shareware VCDS first, because you'll need it to bleed the ABS control block properly.
No need to bleed abs module, unless the module i new or you have sucked the resevoir dry and lots of air in it. Regular brake fluid change done correctly requires no vcds.
Thankfully kept flexible hoses closed so fluid didn't drop too far.Thank you rbhelle.
