Heated steering wheel not enabled
Recommended Posts
I have just bought a 2019 SEL Exec Superb which had a steering wheel clamp previously. This has left an irremovable mark on the steering wheel.
I like the idea of replacing with a heated steering wheel since this is relatively easy to do with a few extras as required from what I understand.
Could I buy the steering wheel with the heated element, but simply replace my existing wheel with it. I could enable  the heated element in the future?
Is this possible?
Link to comment
Share on other sites
if i remember correctly - a heated steering wheel requires a different steering clock spring.  this is due to the differences in the wiring required for the heated steering wheel.
so i don't think it will b possible to simply change the wheel alone.
Link to comment
That's what I understand to get the heated element to work. Can I fit a heated steering wheel without the heated element (so just a steering wheel with buttons working) being enabled or will it not work at all without the replacement clock spring?
Link to comment
@george_d - doubt it will work at all.
A heated steering wheel uses a 14-pin connector.
A non-heated steering wheel uses a 16-pin connector.
Unless u get a Kufatec connector conversion.
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
