Where has Apple CarPlay gone?
It seems the CarPlay icon has gone missing from the Infotainment screen. Looks like it may have disappeared following a routine update?
Anyone know what’s happening with this, if it can be added again, and how to do it?
Thanks in advance
Sounds like the Home Screen(s) have been reset, possibly due to an update of maybe a bit of a glitch in the user profile.
Sometimes if the iPhone doesn't connect the CarPlay icon/app appears as SmartLink. Use that instead and reconnect the phone. If that's not the issue, the you should be able to edit the home screens, a long press should bring up the edit screens where you can add and remove elements, and create additional screens. CarPlay and/or SmartLink should be available in there.
All that typed from memory, hopefully I got it close enough...
Thank you so much, I will give that a try
Thank you so much, I will give that a try-
Pleased to report that this worked, thank you for your help! 🥳
