[Fabia] Window seals
Hello everyone,
I'm looking to replace the window seals on my Fabia MK3 estate. Rubber is dry from the age, and started to crumble.
It's the rubber who is touching the window, i'm not sure what is the technical name, scrapper/aperture seal?
Please advise if those windows seals are replaceable? And what is the technical name or part number to help the search for the part.
Thank you
You can order them from skoda-parts.com. Can recommend them. You can also register and enter your VIN (which is what I did) to make sure all parts will fit, but the link below should fit your Fabia 3.
https://www.skoda-parts.com/catalog/fabia-3/spare-parts/body/doors-and-door-parts-351.html
Select the front/rear doors, then select Window Guide and seal.
I don't know how easy it will be to actually fit them tough. Good luck!
Some parts are easier to get and not a lot more (sometimes less) from the Dealership spare parts department.
