Karoq 2020 SE L TSI 1.5 petrol engine rear fitted camera.
Out of interest I have noticed that the rear camera fitted on my Karoq from new does not align with the kerb if you use the two green lines on the screen. It is a few degrees out and with the nasty low profile tires fitted you can easily scrape the rims with the factory fitted tires.
Has anybody managed to re set the camera on the back so that it shows a true picture on the screen when parking alongside a kerb.
The camera isn't at the centre of the car, so it is unlikely you can do anything about it.
On left hand drive vehicles I’d assume the non central fitting would work to your advantage - that is, giving you a few cm leeway from the kerb?
  • 4 weeks later...
When I get the time after checking the car for it’s MOT I will have a close look at the way it is attached to the rear to see if there is any movement to get the LHS of the green line parallel to the kerb. My son’s Volkswagen GT Polo has a brilliant screen and far better resolution camera than my Karoq.
