Octavia IV 1.5 TSI E-Tec - Low Battery Voltage / Drain Issue
Hi There,
I recently purchased a 21 plate Octavia 1.5 TSI Mild Hybrid (private sale). Nice car, however the car I seem to be having a sporadically issue with low battery voltage. The vehicle is hard to start, starter clicking imitating a dead battery, but will always start on a 2nd attempt. Sometimes this can be a first thing in the morning or after a quick visit to the shops, with the vehicle not being off for more than 5 minutes.
I am also getting sporadic sensor errors (Park Distance Sensor Error, Start/Stop Error, Oil level warning etc), also the entertainment system shuts down, which all points to a low voltage supply.
Here's the thing, there is a very new looking alternator and aux belt on the car, along with a warranty record dated late last year of a battery diagnosis and replacement.
I know they have a 48v starter/alternator system, so I am starting to think I have a deeper issue than a mere battery or alternator issue. I also fear that if the vehicle has been to Skoda before under warranty and the issue was not rectified, it may be a case of throwing parts at the issue (at my expense!), which I am keen to avoid.
Hoping to hear from other Skoda HEV owners if they have experienced this issue?
Thanks in advance.
Edited by SEAN_DUB
  • SEAN_DUB changed the title to Octavia IV 1.5 TSI E-Tec - Low Battery Voltage / Drain Issue
I am having a similar issue with my 2021 1.5 MHEV.
Went away for 3 weeks and the battery was completely dead - unable to be recharged at all. Got the battery replaced under warranty a couple weeks ago, but then got a 12v battery low warning yesterday after not driving it for only two days.
Thought it might be the dash cam I had hard wired into an always powered fuse - even though the hard wire kit says it will cut the power drain if it detects the battery dropping too low - so today I swapped the hard wiring to a switched fuse which only powers the cam when the ignition is on. Going to wait and see how it fares over the next week. Regardless a dash cam shouldn't be draining it so fast over just two days.
  • 10 months later...
Any update?
