Headlight Cleaning System - Intermittent Fault
The headlight cleaning system on my Skoda Yeti L&K 2.0 TD has developed an intermittent fault which I think could be the relay J39.
Screen & rear wash & wipers work fine
The headlight wash pump will occasionally work if I activate it via my OBDeleven device, it will also sometimes work via the steering wheel stalk if I remove fuse 31 & reinsert it.
There are no other electrical problems and no faults show up when I do a scan with the OBDeleven.
I believe relay J39 is connected via plug t52b.
Does anyone know where this plug & relay are and maybe have photos of what needs to be removed to get to them?
What is the intermittent fault you are getting?
If I remember correctly the headlamp washer only washes about  every 5 th  pull of the washer stalk.
The headlamp should wash every first and fifth time the windscreen is washed providing low beam is switched on.
Headlamps don't wash at all under the above conditions but if I remove & reinsert fuse 31 they sometimes do work on the first wash.
If I energise the relay using the OBDeleven device they do sometimes work, but not always.
I would like to find the relay J39 to test it.
