Virtual pedal - FIX
Hello!
I had been experiencing issues with the virtual pedal and couldn't find a way to fix it for almost a year, so I didn't have time to check with the dealer.
I finally found a fix. I don't know how long it will work, but at the moment, it is working, and no error codes are showing, either.
So there is a plug which I assume goes for ignition, you unplug it for a few minutes and plug it back in, close the car, and check if it works, for me it worked. I assume it would be the same for any other VAG as this fix I found for Tiguan.
There are two photos, tried to get as good as I could. Hope it will fix virtual pedal issues for other members.
