Octavia 3 -switched microblade fuse location
Hi. I received new dashcam with hardwire kit. Unfortunately kit is provided with 15A microblade fuse connector. Can somebody help me to locate switched socket for micro fuse to connect it please? I have no multimeter to check it.
Thank you all.
Hi, welcome.
You might be better looking in and/or asking in the Octavia Mk3 forum.  Note VWŠkoda information in 'Owner's Manuals' and possibly elsewhere on fuse locations isn't always accurate, like all sources of information (internet) and databases there can be errors and omissions.
'Skoda Octavia Mk3 (2013 - 2020)' forum - https://www.briskoda.net/forums/forum/235-skoda-octavia-mk3-2013-2020/
HTH.
Thank you very much. It has been sorted already. I connected it to empty slot for righ headlight (slot no. 36) and for permanent power I used KESSY system (no. 19). It is working fine now. Thanks for suggestion anyway.
I hope it doesn't use too much battery power too often, only activates when required, as a 2020 VW will already bash the car 12v battery a fair bit.  Good luck.  The info might be useful to other Octavia Mk3 owners.
