Cheap Talex Lite Deal
Not sure if this is the right thread,
Tesco extra have the talex lite going for
Can you put a link up as i can't find it on site???
It's the Tesco Extra store that I got mine from, sorry should have clarififed.
It's the one by the M27, just before it peels off to the A27, down portsmouth way.
while on the subject does anyone have any mounting tips for an octy?
On the right hand side of the dashboard, run the cable up from the fuse box.
It's got a ciggy lighter socket on it can I just cut that off then I was assuming there might be something in it other than just a connector and a fuse :)
I just hope the sticky isn't too sticky to get off when the time comes.
Yeah snip the ciggy lighter off. Crip a ring tonge to the earth and fix to the earthing stud to the right of the steering wheel (Visible when you drop the lower panel) and take a switched live from the fuse box. It is possible to utilise a spare fuseway on the fuse box and use a small fuse too.
The cable will then run neatly up the right and slide in behind the dash.
Ta, I'll have a look this weekend :)
If you want to use the fuse in the fusebox idea you'll need some wires with the crimps on. I have some here.
Which "department" are they located in the Tesco Extra? As I can't seem to find it!
It's the Tesco Extra store that I got mine from' date=' sorry should have clarififed.
It's the one by the M27, just before it peels off to the A27, down portsmouth way.[/quote']
It a physical store not the online Tesco Extra. If you are at that store you will find it at the very back corner by the TV's etc on the end of a stand. They have a little DVD case which you exchange for the talex lite.
