Turbo, Cam Sensor and Heated O2 sensor Diagnostic code faults
Hi all, I'm asking on behalf of a friend, their car has recently been serviced (I don't know what things were serviced but he has told me the cam shaft sensor was replaced). I only had  about half an hour with it yesterday but the car is cranking and has difficulty starting, then once I did get it started (held both feet on brake and accelerator when turning over) it was struggling to hold idle before stalling. I copied the OBD codes to look at when I got home. They all seem to correspond to either an issue with the Turbo, Cam Sensor or Heated O2 sensor. Has anyone had a similar experience? I'll probably have another look at it next weekend when I have time. DTC's below:
Car Scanner ELM OBD2
Version: 1.114.0/401140/GP
DTC report
Connection profile: Toyota Prius PrimeDate: 2/16/2025 11:00:33 AM
VIN:
OBD-II
No DTC found.
Engine control unit #1Engine control unit #1
DTCs: 63
P003A(41) [0x003A41]
Turbocharger (TC)/supercharger (SC) boost pressure control A - learning limit exceeded
Status: Test not completed since last DTC clear, Test not completed during this operation cycle
P003A(42) [0x003A42]
P003C(58) [0x003C58]
Intake camshaft profile control A, bank 1 - performance or stuck off
P003C(5C) [0x003C5C]
P003C(60) [0x003C60]
P0053(8C) [0x00538C]
Heated oxygen sensor (HO2S), bank 1, sensor 1 - heater resistance
Oxygen Sensor (Bank 1 Sensor 1) Heater Resistance
P0053(97) [0x005397]
P0053(8D) [0x00538D]
P0053(98) [0x005398]
P0053(8E) [0x00538E]
P0053(99) [0x005399]
P003A(CE) [0x003ACE]
P003C(4A) [0x003C4A]
Status: Test not completed during this operation cycle
P003C(4C) [0x003C4C]
P003C(4D) [0x003C4D]
P003C(4B) [0x003C4B]
P003C(52) [0x003C52]
P003C(54) [0x003C54]
P003C(55) [0x003C55]
P003C(53) [0x003C53]
P0050(98) [0x005098]
Heated oxygen sensor (HO2S) 1, bank 2, heater control - circuit malfunction
Oxygen Sensor Heater (Bank 2 Sensor 1) Malfunction
P003B(2C) [0x003B2C]
Turbocharger (TC)/supercharger (SC) boost pressure control B - learning limit exceeded
P0049(F5) [0x0049F5]
Turbocharger (TC)/supercharger (SC) turbine - over-speed
Turbocharger / Supercharger Turbine Over-speed
P003B(4D) [0x003B4D]
P0042(6A) [0x00426A]
Heated oxygen sensor (HO2S) 3, bank 1, heater control - circuit malfunction
Oxygen Sensor Heater (Bank 1 Sensor 3) Malfunction
P003B(5E) [0x003B5E]
P003B(60) [0x003B60]
P003B(58) [0x003B58]
P003B(66) [0x003B66]
P0053(8F) [0x00538F]
P0053(9A) [0x00539A]
P0053(90) [0x005390]
P0053(9B) [0x00539B]
P0053(91) [0x005391]
P0053(9C) [0x00539C]
P003B(87) [0x003B87]
P003B(9B) [0x003B9B]
P0053(E1) [0x0053E1]
P0053(E2) [0x0053E2]
P0053(E9) [0x0053E9]
P003C(07) [0x003C07]
P003C(84) [0x003C84]
P003C(08) [0x003C08]
P003C(85) [0x003C85]
P0039(EE) [0x0039EE]
Turbocharger (TC) bypass valve/supercharger (SC) bypass valve, control - range/performance problem
Turbocharger / Supercharger Bypass Valve Control Circuit Range / Performance
P003A(9F) [0x003A9F]
P003A(9D) [0x003A9D]
P003A(F0) [0x003AF0]
P003A(EF) [0x003AEF]
P003A(E5) [0x003AE5]
P003A(E6) [0x003AE6]
P0046(00) [0x004600]
Turbocharger (TC) boost control solenoid/supercharger (SC) boost control solenoid - circuit range/performance; Turbocharger 1 Wastegate Solenoid Valve Control Circuit High Temperature
Turbocharger / Supercharger Boost Control Solenoid Circuit Range / Performance
P0050(A8) [0x0050A8]
P0050(A0) [0x0050A0]
P003B(69) [0x003B69]
P003B(B8) [0x003BB8]
P003B(B5) [0x003BB5]
P003A(C1) [0x003AC1]
P003A(C2) [0x003AC2]
P003A(C4) [0x003AC4]
P003A(D1) [0x003AD1]
P003A(D2) [0x003AD2]
P003A(D3) [0x003AD3]
Transmission control unit #1Transmission control unit #1
DTCs: 63
P0052(9B) [0x00529B]
Heated oxygen sensor (HO2S) 1, bank 2, heater control - circuit high
Oxygen Sensor Heater (Bank 2 Sensor 1) Circuit High
P0052(9C) [0x00529C]
P0052(9D) [0x00529D]
P0052(9E) [0x00529E]
P0052(9F) [0x00529F]
P0052(A0) [0x0052A0]
P0052(A1) [0x0052A1]
P0052(A2) [0x0052A2]
P0052(A3) [0x0052A3]
P0052(A4) [0x0052A4]
P0052(A5) [0x0052A5]
P0052(A6) [0x0052A6]
P0052(A7) [0x0052A7]
P0052(A8) [0x0052A8]
P0029(DD) [0x0029DD]
Exhaust valve control solenoid, bank 2 - range/performance problem
Exhaust valve Control Solenoid Circuit Bank 2 Range / Performance
P0029(DE) [0x0029DE]
P0029(DF) [0x0029DF]
P0029(E0) [0x0029E0]
P0029(E1) [0x0029E1]
P0029(E2) [0x0029E2]
P0029(E4) [0x0029E4]
P0052(A9) [0x0052A9]
P0052(AA) [0x0052AA]
P0052(AB) [0x0052AB]
P0052(AC) [0x0052AC]
P0052(AD) [0x0052AD]
P0052(AE) [0x0052AE]
P0052(AF) [0x0052AF]
P0029(FB) [0x0029FB]
P0029(FC) [0x0029FC]
P0029(9E) [0x00299E]
P0029(EB) [0x0029EB]
P0029(EC) [0x0029EC]
P0052(B2) [0x0052B2]
P0052(B3) [0x0052B3]
P0029(A1) [0x0029A1]
P0033(1B) [0x00331B]
Turbocharger (TC) bypass valve - circuit malfunction
Turbocharger Wastegate Regulating Valve Circuit Malfunction
P0029(F3) [0x0029F3]
P0029(F4) [0x0029F4]
P002A(9E) [0x002A9E]
Exhaust camshaft profile control B, bank 1 - open circuit
P002A(9D) [0x002A9D]
P0029(F5) [0x0029F5]
P0029(F7) [0x0029F7]
P0029(F6) [0x0029F6]
P0029(F8) [0x0029F8]
P0029(F9) [0x0029F9]
P0029(FA) [0x0029FA]
P0052(B6) [0x0052B6]
P0052(D7) [0x0052D7]
P002A(9A) [0x002A9A]
P0052(B7) [0x0052B7]
P002A(05) [0x002A05]
P002A(45) [0x002A45]
P002A(B0) [0x002AB0]
P002A(14) [0x002A14]
P0029(C5) [0x0029C5]
P002A(13) [0x002A13]
P002A(18) [0x002A18]
P0029(C6) [0x0029C6]
P002A(17) [0x002A17]
P0052(BC) [0x0052BC]
P0052(BD) [0x0052BD]
P0052(BE) [0x0052BE]
PS: Toyota list DTC's and steps to troubleshoot in their service manuals. Does Skoda do something similar? I was unable to find listed DTC's in their workshop maintenance manual.
