Webasto Thermo Top V in a 2011 Skoda Superb II - Telestart T91 does not turn on the blower
Good morning,
I have installed a Webasto Thermo Top V with a Telestart T91 in a 2011 Skoda Superb II 3.6. Everything works correctly, except for the Telestart.
When I start Webasto using the remote, the heater turns on, but the Climatronic panel does not activate, meaning the blower does not run. However, when I start it from the FIS panel (by programming the start time) or using the button on the Climatronic panel, both the heater and the blower work correctly.
The Telestart is connected via three pins:
1 - 12V
2 - W-BUS, connected to the heater on pin 2
6 - Ground
What can I do to make the remote activate the blower?
Probably nees to pair it with the receiver from webasto. At least if it is the same webasto system and remote that the car was delivered from factory. If it is a retrofit webasto this can be done via vcds or by following the manual from original webasto supplier. If it is a new original remote from factory, they habe probably forgot to recode it. If remote is new bought from ebay, and webasto is still the same factory mounted. Well, then you are likely f.....d and have to get a new one from factory dealer (remote)
The devices are paired, the remote control activates the Webasto heater, which warms the coolant in the system, but the Climatronic panel is off and is not blowing warm air into the cabin.
