Superb 2016 inner lights problem
Hi my Skoda superb lights not working i have changed battery. fuses are ok. seat warmer not working. ambient light foot light and sunroof light not working. when i start the car screen reduces its light. they say that body control module has to be changed and coded. is there any other option. can this bcm ( 5Q0937084CG ) fixed. Sorry for my English.
  • 4 months later...
Hi - have exactly the same issue - came out from nowhere.
Changed the CAN GATEWAY MODULE (bought a second hand one and cloned it) worked perfectly for one month and after - exactly the same thing.
Would you mind sharing how did you managed to sort this issue.
Thank you in advance
First you must change the battery. if it's low voltage same thing happens they said.
