Intermittent starting issue
Hi, so thought I'd ask the forum this when I go to work at 6am in the morning my car starts fine no issues even when cold I then drive 6 miles to work and leave it there till 4pm when I leave work and try start it it cranks over few times then starts and kicks out smoke , then drives and starts ok after that , then drive 6 miles home and leave over night till 6am an no starting issue only when I seem to leave work
Smoke suggests it's stuck in cold start mode, which points to a temperature sensor?
Is they any way of me testing the temp sensor ? And is this the coolant temperature sensor as funny enough my temp gauge goes up fast and stays in the middle
Edited by Holderness88
There is more than 1 temperature sensor, I think it could also be the one measuring intake air temperature - so rather than guessing I suggest a code scan.
I have a diagnostic machine , launch x431 pro and it only has theseScreenshot_20250419-171445_Chrome_1.jpg
Do you have a friend with either OBDeleven or VCDS - they give a much more in depth report?
Unfortunately not no I presume OBDeleven is the Bluetooth one to your phone ?
No idea, I use VCDS and a Windows 11 2-in-1 laptop but lots of people on here use OBDeleven.
Edited by PetrolDave
My diagnostic machine should work though surely it's up to date and Its bidirectional or do you mean specifically for Skodas ?
I mean one that properly understands VW Group vehicles and their specific fault codes, not just the generic OBD fault codes.
Ah yeah I see what you mean, I'll have to have a ask about or take a drive to yours haha
Cheers Dave
Is it a TDI or TSI vRS being discussed?
TDI the 181 bhp
This should have been the first question. Check the glow plugs.
I was told if it starts in cold weather without issues then won't be glow plugs I'll have to get a multimeter out on them
Issue apparently solved was a split line to the fuel filter now been replaced seems to have sorted it
