changed steering wheel 3 spoke to 2 spoke, lost button function
Hello guys,
I need some help here! Purely from a vanity standpoint, I’ve changed my steering wheel. After installation, the buttons to the left pertaining to multimedia (music, volume, skip tracks etc) are working fine. However I noticed that the view button from the old steering wheel was not replaced by any of the ones of the new wheel, everything work perfectly all the other buttons are fine.
now i would not mind it that much, but there is no other option to be able to change the cockpit view from some reason from anywhere else.
Does anyone have any idea how to fix this.
No expert, but would have thought the similar new style 3 spoke would be have been a straight swap, whereas fitting the older style might need coding or different buttons fitted.
so i've changed from the old 3 spoke one to the 2 spoke new, not the other way around.
Edited by Alica11
The Kommunikation from the New Button (LIN) is Not the same. You need a LIN Emulator
you have any idea were i can find something like that?
thanks
