Front Facing Camera on a 2025 Skoda Superb Lauren & Klemin 200 diesel estate
Hi,
I have noticed that the image on the screen inside the car was fuzzy and thought the camera needed a clean. It looks like a stone has hit the camera on the front of the car. Does anyone know what is involved in replacing this? Thanks
The camera is located behind the windscreen. So most likely you don't have to replace the camera, but the windscreen. Or maybe it can be repaired with spot repair?
I think the OP is referring to the front facing camera which is part of the area view (360) system on the L&K.
Camera is in the front grille.
I would expect that from the service manual point of view entire new front radar cover with embedded camera will be needed.
@Roadrunner88
Just call the service desk at the dealer and they should tell you what should be replaced from their service manual.
Thank you for your suggestion.
