Help, please...screen message.
After an MOT earlier this year, we noticed the compass rose image had been replaced by "No entries available". Photo attached.
I can't find any reference to this anywhere, so any suggestions as to how to get the compass back would be appreciated.
Nicephore
Edited by Nicephore
spelling...
Hello, welcome to the forum.
If you have multi-function steering wheel, use the RH scroll wheel to show a different menu on the Maxi Dot display, then press to select.
What happens when you try to change the section?
Correction to my post, press the 'Back' switch first - this will display a menu band, then use thumb wheel to scroll to 'Navigation' Press scroll wheel to select. Compass rose will display.
Bingo!! Thanks for that......9 years we've had it, and I don't think I've ever touched those buttons....🙄
Nicephore
Actually, I'm not new here....I joined when I bought the car nine years ago, it's just been so utterly reliable that I haven't had to call upon the experts.
Very frugal on juice and totally practical, it's easily the best car I've ever owned, and there have been quite a few.
If I was asked if it could be improved, I'd say a rear seat base that lifted up and forward so that the rear seat back could lay fully down to give a flat load area would be the cherry on top.
I could sleep in it then...
Nicephore
