starting problems
Twice in the last month my 1.4 16v has had trouble starting. When you turn the key the car vibrates and doesn`t seem to catch into life, then i tried to start it again the vibrations stop and then after a while catches into life.
I then turn the car off and then restart and it`s fine.
I was wondering if it due to the weather as it`s hot and if the petrol evaporates so it takes longer for the fuel to get to the jets.
If tried to figure this out but can`t seem to work it out, has anyone had this problem and if so what was it.
Need to check it with VAG COM etc, but id be tempted to have a look at the coolant temp sensor, see if its a green one. It sits down the right hand side of the cylinder head at the front. Just by the EGR pipes.
I just went to have a look, but can`t see anything green. I wish there was a Haynes manual for the Fabia.
I might ring Skoda tomorrow and see what they suggest.
I would put money on a coolant sensor myself ;)
Ross has it, my brothers ibiza 1.4 8v had the same prob.
If it is the sesor, is it easy to fix, or is it best to take it to a garage.
Its a little bit fiddly on the 16v.
Cheers i`ll ring the garage tomorrow.
I just had a look on the Haynes website and there`s a manual coming out in December this year.
I rang the Skoda garage up today and he instantly said "It`s the temperature sensor", exactly what you guy`s said. So i`ve booked it in for next week to be sorted.
Cheers guy`s once again you`ve come to the rescue.
Got the garage to change the temp sensor today. 45 mins work and a bill for
