Missing/not working telephone/bluetooth?
Hey there, I just recently bought a Fabia (2015) and was wondering if why my bluetooth does not work as intended. I attached pictures below showing the errors I've encountered. Thank you in advance for any help.
Also, if possible, is there any way to integrate carplay or update it so mirrorlink can be unlocked.
VIN TMBFM6NJ7FZ034217
Edit: Bolero infotainment system
Car Model: Fabia SE L 1.2 TSI
Bluetooth is missing from the setup menu.
Edited by nkdmns
just in case
Probably the unit is broken - either HW or SW. Start with checking installed FEC/SWaP codes - go to service menu (long press MENU bottom) and check if you have FEC/SWaP menu available. If you don't you have to enable developer mode in adaptations with VCDS, VCP, ODIS, VC Tool (requires enabling security first with code S12345).
Appreciate the reply, ill try get a hold of a VDS soon.
Hey i ran a coding 07 vcds controller unlocking the access with code 20103. Where do i go from here? Thanks
