Fabia VCDS
Just purchased a 71’ plate fabia Monte Carlo for the wife and have a few questions that I couldn’t find the answers for.
I have the old VCDS hex+can cable and after a scan,I realised that some of the modules are aren’t readable.Do I just need the hex v2 cable now so I can make some adaptions adjusting the following?
Coming home lights
Auto lock above 15kph
Needle sweep
Cornering fog lights
Auto lights? Do I just need coding plus a different switch
Been off the scene a few years and sons fabia 18’ plate SEL came with most of these adjustable via the head unit, plus my cable worked on his car fine.
TIA
Yes you now need to upgrade your VCDS, I traded my old VAG COM and then VCDS Hex+Can back into the original seller (Gendan), but if you are brave, you might get a lot more money for it if you sell it on to someone.
I think that it was when my daughter bought a 2019 car that thought that it was time to upgrade.
Purchase options are a bit limiting though, I went for the "10 VIN" package and that has worked well enough for me over the past 6 years, there is a "3 VIN" package as well I think.
