DCC Damper Fault
Just info in case it happens to anyone else. My 9 month old Mark 4.5 Octavia RS wagon started flashing up a Damper Fault recently with each engine start along with the damper logo and warning triangle. The manual said off to the dealer so I sent it in yesterday and had a Scala 85kW loaner (very gutless and way too much turbo lag off the bottom end before it gets going) for the day. The issue turned out to be a speed sensor that had become detached from the system. Hopefully that is that and onwards we go. This is unfortunately the second warranty issue in 9 months (first was battery replacement). It is reinforcing the view that VAG vehicles really are something you only want with a warranty.
