Boinging noise ... mk2 vrs
Afternoon , merry Christmas and hope you all well, help and advice needed please , mk2 vrs when going from one speed limit to another all of a sudden there is mow a boinging noise , is there a way of switching it off , thanks
Hi there, probably some details would be needed to get an answer. A video or some better descritpion of the issue, please.
Revisiting this, if this is about the speed limit assistant, yes, it can be turned off, but it must be done at each engine startup. I've added a shortcut to my screen, or you can press the drive assistant button on the steering wheel then use the scroll to deactivate the speed limit thing.
