How to remove the boot panel?
Anyone know how to remove the interior plastic panel on th boot hatch?
I need to sound deaden the hatch to stop the vibrations :D
yeah it is a pain in the a##e to get off , just got to pull like mad , realigning the side trims is a bit of a nightmare also
Cheers. Sounds like I'll be having fun.
Found that a flat wooden kitchen sputula is a good tool to use to pop off the first few clips, start at one side, then work your way downwards, along the bottom and then up the other side. By this time the thing will be half hanging off and should surrender without use of anything but hand pressure.
Oh yes, when re-fitting, dont forget to feed the fabric strap (short persons handle) back through the trim panel before you go too far, or you will end up doing te job twice
Dont ask me how I know.
Regards
Rob
