Bonnet not closing - stiff release cable SORTED
Afternoon all...
Just had an issue with my (now getting on a bit) Superb after topping up the washer, the bonnet wouldn't latch shut.
It just bounced back up when trying to close resulting in panic/stress as its needed for work..
I pulled the release lever and tried again and it closed this time thankfully but seeking thoughts on how to proceed without getting stuck with an open bonnet.
I didn't want to re-open until prepared to deal with it to avoid being stuck...
The release lever has been stiff for as long as I can remember despite regular dosing the latch mechanism with WD40/lithium grease spray, just assumed it was a Superb trait...
The catch lever under the bonnet is very free moving as I know that can seize up.
I guess a couple of questions -
Can you get to the cable end to lubricate directly, couldn't really see ? Thinking I will direct copious amounts of spray into the cable end.
Is there a joint in the cable or mechanism under the slam panel which needs lubricating ?
Any recommended spray lubricant ? (I have been using white lithium with no issues until now...)
Is it better to replace the cable entirely ? (anyone have a part number or diagram of the installation ?)
UPDATE 28/02/26
So I have basically answered my questions with a bit of investigation and I'd recommend any Mk2 owner doing this as a bit of preventative maintenance.
Cleaned up the bonnet latch with a load of brake cleaner which got rid of a lot of old white lithium grease that had congeled along with a bit or road dirt etc.
Did the same for the release mechanism lever which was already free but did no harm.
I then had a poke around and found the cable joint mechanism under the slam panel just above the nearside headlamp.
This is held by a couple of clips which easily pulls off to give better access to the arrangement.
I know that this housing is where the cable joint can get detached but mine remained intact.
The housing clearly can come apart which means spray oil can penetrate so I doused about half a can of 'Rocket' spray into each end of the cable, and also all over.
A rag placed beneath caught all the drips.
I worked the release lever and immediately noticed a massive difference, it has freed up hugely and is now springing back as you'd expect.
So this joint housing seems to be the cause of a lot of the sticking issues so a liberal douse of spray every so often should keep it free and might stop your bonnet cable becoming detached.
20260228_171843
20260228_171043
20260228_171057
20260228_171953
Many thanks
Dave
Edited by TasMan
  • TasMan changed the title to Bonnet not closing - stiff release cable SORTED
