broken windscreen(front window)
hello guys
i have just two days ago find out that my front window is broken on the left bottom side,like 40cm.i dont know if it happened from a stone or from deforming the body of the car.also i have front strut brace,but could it be possible tha from taking the curves fast can i deform the body,and thats why can the window break from any reason.or can it be from big heat or what esle?please tell me what do you think.
ivan
I would think its due to a stone. Any windscreen company could tell you for sure.
BTW WRC rally cars use standard windscreens if I remember correctly and they are pretty rigid. I doubt a road car would give that much problems.
could be from body flex , but would take some flex to crack it , although i've seen quite a few Ford KAs with cracked screens through flex , and recently a new Focus , so its not impossible
Having thought about it though rally cars would flex less due to being stiff so my previous statement is really a bit wrong.
However Ive not seen a Fabia do it as yet. Seen a mates Racing Puma crack the bulkhead from the extra loading due to the wider suspension etc, not good.
thanks guys to your thougts,i was at skoda dealer(owner my very good friend)and he found where the stone hit the screen,so i it was from a stone,i was just little bit affraid that my body flex too much.
thanks
