skoda superb mk II rear subframe replacement
hello everyone,
I'm starting this topic as I couldn't find any info on it.
I need to replace the rear subframe on a skoda superb mk 2 2015 2.0 tdi 170
the problem is that I can't find a replacement part online. All the subframes on ebay are for mk3
does anyone know if the mk2 and mk3 use the same rear subframe
thank you
First a question: Why do you want to replace the subframe?
If you know the the exact type number, you can look for that. My 2WD 2012 S2 has the 5N0505235Q, but that number was (according to my ETKA) only used until 27-05-2012, so yours will have a different number. And the 4WD models also have a different part.
Edited by andrehj
Hello,
It's corroded.
It has a hole in it beyond repair.
I think i found the part number 5N0505235AE
Think they used the same subframe as in the 4wd models
Ouch, that is quite severe. I painted mine two years ago since it started to develop rust, and I hate that.
Currently it looks like this (picture taken from the right side):
I'm telling you it's the one listed as 4wd
That's correct, the picture above shows a subframe for 4WD. The question is whether this will also fit the 2WD version...
