Haldex versions
Hi everyone
So my mk3 Tour de France has had its Haldex eat itself - I’m struggling to locate a replacement. If I go for an updated part number or superseded version - how new can I go before it won’t work or will any newer versions work. My initial research says any Will work you just do A Haldex relearn but I’m skeptical with all the ai derived horseapples on the internet now.
For reference I have a gen 5 Haldex with the OCQ 907 554d could I use a 907 554j for example?
Thanks legends
  • 4 months later...
Hi, I've got the same problem with my 2014 MK3 Tour De France.
And yes, it is proving very difficult to find a replacement. Although I have been quoted £7500 to repair 🤯🤯🤯
My garage said cheaper/easier to get a 'new' axle with haldex already fitted and swap it over.
Did you find a solution to the problem?
Yea, I got one from an s3 Audi after a few months looking around. part nos matched
Ahhh. I did wonder if it would be compatible if it was from a different car. But as long as the numbers match I suppose it should be fine.
Cheers
Still hoping to find an axle with haldex fitted for easier/cheaper fitting but thank you for the very useful info 👍
Recently Browsing 1
