Engine mount - good or bad
Hello,
I need a second opinion on this engine mount, I believe that it's gone and I plan to replace it.
When the engine is running it's more-less ok, but it shakes a lot during starting.
P.S. I might replace the lower engine mount as well (one from the front subframe that connects to the gearbox).
P.P.S. Car in question is Fabia 1.4 MPI 50KW
Thanks a lot
  • Sponsor
I expect the lower mount will make a much bigger difference.
Dogbone one at gearbox watch the bolts. On my sons there are two but one is longer than the other. If you mix them up you can wreck the steering rack which is above. Top ones look ok but difficult to tell. Maybe replace gearbox one first and see if it make a difference.
Alasdair
