RAPID 2014 1.2 tsi
Hi all. I am about to tackle this subject again now that I am well enough. I have an 'oil leak' from the rear of the block midwayish but sump plug end. This appears to come from the oil seperator / diverter and one way valve area but as with a lot of leaks difficult to pin down. I am going to change the one way valve myself and would like to do the diverter myself too. Has anyone on here either done this on their car or if not has had it done by a mechanic and if so how much. Any tips/info on doing either job will be very welcome.Pic shows the diverter I am talking about. Thanks in advance. Grahams-l1600.webp
Have you looked at the throttle body area, in case it's running down from up there?
Do you mean the one way valve that connects via a hose to the airbox area? If it's not broken/detached I'd say there's no point in changing that.
The oil separator is not a nice job. I think I already pointed you to my thread where I describe it, but in a nutshell it needs to be done from below, and the offside driveshaft needs to be removed first for access. Best done on a lift, indoors, after ruling out all other sources of the leakage. Not sure what a garage would quote, ask one.
