CD changer connections: Octy2 and Fabia
Do headunits fitted to the Octy2 use the same type of CD changer connection as the HU in the Fabia?
Thanks,
Steve
In short, no mate. I'm not sure about the latest 2006/2007 Fabia's though.
If it's what I think you are interested in then have a look on my website and all will become clear.
Thanks Stu, as ever! :thumbup:
You don't happen to know a place where you can get the other cable do you?
Cheers,
Steve
If you want the OEM Denison then I think it's a complete kit.
Alternatively you could try Denison but I think they've discontinued the Ice Link.
cut the plug off the fabia cable you have, get the relevant connector and flyleads from skoda and replace it with that. When it comes to matching pinouts I can sort you out.
Have you bought the Ipod connector then?
As Johnny says you could cut the cable and crimp on new parts -
Fabia parts are -
6 pin Multi Connector (Yellow) VAG Part Number 4A0 972 643 (Approximately £2.05 each)
6 pin Multi Connector (Green) VAG Part Number 4A0 972 643A (Approximately £2.05 each)
6 pin Multi Connector (Blue) VAG Part Number 4A0 972 643B (Approximately £2.05 each)
Single Wires VAG Part Number 000 979 131 (Only sold in quantities of 5 approximately £5.25 for the 5 items)
Fabia Pin Outs -
20 Pin Multi Connector Blue Section
13. CD Changer - Data In
14. CD Changer - Data Out
15. CD Changer - Clock
16. CD Changer - Positive (B+) Supply
17. CD Changer - Control Signal
18. CD Changer - Ground (GND)
19. CD Changer - Line Out Left
20. CD Changer - Line Out Right
Octavia Pin Outs -
Multipin plug connection -B-, 12-pin
2 - CD changer, left and right channel, earth
4 - CD changer, voltage supply, terminal 30
6 - CD changer, DATA OUT
8 - CD changer, left channel, CD/L
9 - CD changer, right channel, CD/R
10 - CD changer, control signal
11 - CD changer, DATA IN
12 - CD changer, CLOCK
Nope, not yet - just looking at options. Thanks for the connector info though :thumbup:
Steve
Just to confirm, there seems to be two mini-ISO connectors for VAG group vehicles. So does the Fabia use 8-pin or 20-pin? Have a feeling it's 8, but want to be sure...
Thanks,
Steve
Click the link and all will be revealed Steve.
Fabia parts are -
