blower motor on fabia SDI weak as a kitten but all 4 speeds working?
The blower on my fabia sounds like it changes up when i select each of the 4 speeds but you cant really even feel it till its on speed 4 and then so mildly that it has no effect :(
Does anyone have an ideas on what may be causing this?
Or where the motor is located and I'll take it off and test it?
RTich
does it sound beefy? If it does, you may have a pipe come loose or something ?
i'd check that the pollen filter is not blocked in the n/s footwell area , or the air intake under the scuttle panel could be full of leaves
the problem will be the pollen filter is blocked. i would check it out, easy to do mate.
Thats sweet!!
Thanks very much you guys
Rich
I changed mine today and it's made a hell of a difference! Only took about 10 minutes as well. :D
