Vrs Front foglight beam height
Having used the search facility to find if the front fogs on a Furby had be adjusted for up and down, does anyone know how you set them up?
Should they shine in a horizontal beam - straight out or should they point down to the ground in a certain place at a given distance in front of the car.
Was a bit foggy this morning on way to work. One light (f/n/s) is pointing down and the f/o/s shines straight out.
Osram All Seasons (Super) Bulbs are installed.
Thanks in advance for help to set these up properly.
1. Dont know how they adjust. If you join Freedom you can 'Ask a Tech'
2. How did you change the bulbs? Or should I 'Ask a tech'?
Chris
I changed them with a lot of difficulty but really feel it is a bumper off job to do it properly.
There is a small torx "screw" in one of the top corners of the light housing, visible when the trim is removed that sets the height of the beam.
May have to join Freedom.
