Cable from the engine bay into the car - Octy II - Pics
This may help someone...
These pictures show how the power cables (for a caravan) have been taken through the bulkhead. They were added by the dealer to the factory fitted 13pin towing electrics.
Very useful - Thanks
That will come in useful very soon, thanks :thumbup:
theres also a very usefull handbrake cable hole on the nearside of the plenum chamber, for left hand drive vehicles, this is plenty big enough to run cables through,
Hi, Is there a problem? as I can not any pictures when viewing this post - and this is something I am very interested in.
Can you re-post the pics please
Sorry the hosting web server is down at the moment - engineers are working on it!
If you want to send them over to me I'll add them to Octavia-vrs.com.
Thanks Guys
HI, I have now had a chance to look at my car and can see that the pics only show where the wires go into the Air Intake area. I have lifted the air intake cover and can see no obvious route for the wires into the inside of the car - do you have any further info on where they enter the car, assuming they do and were not run under the car.
  • 11 months later...
Yes if you look at the picture in the thread above, then lift the cover under the wipers and follow back to the next bulkhead, there is a rubber grommet there.
Remove the glove box and you will be able to pass a cable through to behind the glovebox area. There is some foam which needs pushing aside.
Easiest way to locate the hole from glovebox side is to shine a bright light through the grommet hole on the engine side.
Hope this helps.:thumbup:
thanks for the reply Phil, surprised you found the thread after all this time.
As I have a DSG and managed to thread the wires through the rubber blanking piece where the clutch pedal would fit on a manual.
Will be running more wires soon so will probably follow your advice
