radio
Why does my Felicias radio still remain on after i have turned off the ignition???? Derek.
The radio should be connected to the battery without passing through the ignition circuit, so you can turn it on (with the on/off button) even if the keys aren't in. As you've noted, though, it should turn off when you take the keys out. It's possible that there's a problem with the electronic signal that goes from the ignition to the stereo to tell it to turn off, and the most likely cause would be if there's a problem with the connector at the back of the radio. Whip the radio out, and give the connector a bit of a jiggle and perhaps a squirt with a little bit of WD40 to see if that fixes it...
Many thanks. Derek.
