Front Parking Sensors
Does anyone know if it is possible to have front sensors fitted to the Superb/ Has anyone done this - is it a Dealer option accessory?
It should be possible, they are available for the Oct'y.
Ask your local dealer they might be able help ;)
I've just looked at the Skodas UK website and they only list the rear sensors as an option at
Thanks Guys - will ask Dealer and if they can't help I think I know a man who can in Canterbury (Canterbury car Radio). I had rear sensors fitted by them on two cars a couple of years ago and both worked fine up to the day the cars were sold.
Thanks again.
Your latter option sounds like your best bet to be honest...HTH:)
Quick update - Dealer has quoted £700 and canterbury Car Radio £300 to £350 depending on whether I have colour coded or not. A big difference and I think CCR will be getting the job.
Thanks for your answers.
I have them on the front of my Octy (aftermarket ones not OEM) in heavy rain / snow etc they go off all the time.
Not sure if the OEM ones have a speed sensor that overrides the system above a certain speed, but if not, then think long and hard before opting for the front sensors.
My front ones are mainly turned off :rolleyes:
Thanks for the info Gizmo68 - I think you are correct as having looked at the cowson of a job to fit them I don't think it's worth it.
Regards
I notice their listed for the Octavia at the Skoda accessories site for
The front's on my old Octavia were always on with the ignition, so yep they do get VERY annoying - I wouldn't have front sensors again!
I had an SMax for a short while with front (and rear) sensors.
Both were activated by engaging reverse, and stopped working above about 10 mph.
The fronts could be a pain in traffic, but there was a button on the dash to de-activate them.
Fronts and rears also had different frequencies - very useful in tight parking.
Is there an option to deactivate front sensors on the Octy II?
only car I've driven with front sensors is a BMW 535d - now that's one seriously mean piece of kit - which was like the S-max above. The sensors come on when you select reverse and stay on unless you deactivate them by a switch.:thumbup:
just read the thread about the L&K. Seems to be available as a factory option, so order a new car!!:D
http://www.briskoda.net/forums/superb/l-k-out/74937/
