Wiring diagram audience
Does anybody have the wiring diagram for the amp thats located under the drivers seat? My car: 2007 Octy vRs with Audince and 12 speakers. My plan is to fit a subwoofer and i want to find the remote cable and left rear /right rear speaker cables without testing all the cables thats connected to the amp.
Multipin plug connection -A-, 23-pin
1 - Midrange speaker rear left +
2 - Midrange speaker rear left -
3 - Bass speaker rear left +
4 - Bass speaker rear right +
5 - Bass speaker rear right -
6 - Bass speaker rear left -
7 - Midrange speaker rear right +
8 - Midrange speaker rear right -
9 - not assigned
10 - Midrange speaker front left +
11 - Midrange speaker front left -
12 - Bass speaker front left +
13 - Bass speaker front right +
14 - Bass speaker front right -
15 - Bass speaker front left -
16 - Midrange speaker front right +
17 - Midrange speaker front right -
18 - Terminal 30; + 12 V
19 - Terminal 31; earth
20 - Terminal 31; earth
21 - Terminal 30; + 12 V
22 - Terminal 31; earth
23 - Terminal 30; + 12 V
Multipin plug connection -B-, 24-pin
1 - CAN databus High
2 - not assigned
3 - CAN databus Low
4 - not assigned
5 - not assigned
6 - not assigned
7 - not assigned
8 - not assigned
9 - not assigned
10 - not assigned
11 - Radio NF signal front left +
12 - Radio NF signal front left -
13 - not assigned
14 - Radio NF signal front right +
15 - Radio NF signal front right -
16 - not assigned
17 - Radio NF signal rear left +
18 - Radio NF signal rear left -
19 - not assigned
20 - Radio NF signal front right +
21 - Radio NF signal front right -
22 - not assigned
23 - not assigned
24 - not assigned
Thanks for quick response..
No problem. Bet your dealer wouldn't even be that quick!! :D
[hint]You might also note I am a Freedom Pimp[/hint]
My dealer did not know that there was an amp under the seat!!
What is radio NF- signal? What can i use as remotecable to the active subwoofer?
Do you mean a switched live?
I mean that my active sub has a cable with a piece of tape that says "remote". This one have to be plugged so the amplifier in the sub starts up when the radio/ ignitionswitch is turned on.
So in short then you mean a switched live.
There isn't one on the Amp.
Ok. Thanks. I`ll figure it out
If you want a switched supply you'll need to source one from the fuse panel.
The Octy II audio is switched via CANBUS.
Ok. Thanks again.
