Maxidot - "Convenience" Settings???
Anyone know if the 07 MY Superb has the Convenience settings in the Maxidot unit and if so, how do you access them??
Cheers... Num
Don't know about the Superb but got this wee snippet from another thread (think it was for an octy)
"You need the car to be stationary. hold down the toggle switch on the end of the stalk. This gets you into the main menu. Then scroll to 'vehicle settings' (i think) and select using the button below the stalk. Scroll to 'convenience indicator' and select it. then just change setting to 'on'."
http://www.briskoda.net/forums/diagnostics-vag-com/3-flash-indicators/55668/
Edit:
Just tried it on my Sept 06 Superb and only options on main menu are 'navigation', 'car status' and the normal trip computer one - doesn't look like it can be done :(
Edit:
Thanks bigbadgoggs, I found that too, but I wondered if any additional settings can be accessed via VAGcom, or any other "tweeks?" Anyone know?
Num
Bumpo! :)
Last attempt :)
