Fabia VRS Rear Speaker Replacement
Hi,
Has anyone replaced their rear 10cm speakers?
If so, did you have to remove the seat belty units to get to the last screw on the speaker?
(Don't want a stealth shelf and 6x9s yet... I've got a 12" sub and amp to fit at some point!)
Am thinking of putting in some pioneer custom fit jobs.
Cheers for your thoughts,
Si.
dont bother with rear speakers, stick with fornts and sub, believe me here have you disconnected the rear tweeters yet as these are so annoying?
The reason i say no to rear speakers is because the pressure from the sub will act tot he rear of the cones and cause over dispacement, and hence damage the cones and cause odd peaks and troughs in the music
