Nokia E90 and N95 problem
:confused: dear Friends:
I just got me new Nokia communicator E90 , running Sympian S60 v.3 and i can pair easly with my builtin factory installed Octavia bluetooth car kit, but m there is no sync for call log or phone book...
is there anything that I can do ???
thanks
I don't think they are fully compatable with the remote addressbook.
Sure enough, if you had a nokia kit.........
I have a parrot at the moment, I needed to do a push of the address book via BT, works perfectly (just marked all contacts, and pushed via BT)
i tried to push by markall and send as business card ,,, but car kit refused to accept the incoming .... is there any other way around ? is there any way to hard reset the car kit???
How about a sync using the sync manager on the N95 to push to the car BT kit?
Otherwise I'm out of idea's. What firmware's the N95 running?
thanks
As I understood so far, Symbian OS is not compatible with Skoda Bluetooth system for phonebook.
i have the latest firm ware and still same problem for both N95 and E90 , thanks alot for your efforts, I tried the sync and still not working , the car kit is refusing to recive the contacts, or maybe something is fishy. do you have any idea what is the file that holds the contacts list in the BT car kit ???? when i try to configure the sync its asking about the remote database file name.
thanks for all ....
