Cambelt Change
HI can someone please help me, i need a cambelt change and my car has been remapped, does this make any difference when having the cambelt changed
Also which parts should i get replaced while having the cambelt changed i have seen i need the waterpump but are there any other parts i need done.
Finally i am in bristol is there anyone who can tell me where the best place to get it done is.
Would be helpfull if we knew what car you had.
Sorry Octavia Vrs mk1
shouldn't make a difference.
usual disclaimer applies
Sorry what do you mean by usual disclaimer applies and also which parts do i require changing
thanks
Can anyone help
You require
Cambelt
Tensioner roller
Tensioner damper
Water pump
Mounting bolts.
Can anyone help
Are you planning on doing this yourself then? if so have you got the Haynes manual.
If you plan on getting your garage to do it, just ask them if they have a problem with servicing remapped cars. (my seller told me that in theory they shy away, but the servicing is EXACTLY the same; its only a bit of software that changed and they will be able to read out the fact that it has been changed. that's about it)
what is it you are worried about mate?
Not doing it myself, just worried about them messing with the remap and maybe putting back to standard
I can't imagine they'd have any reason to go anywhere near the ECU except to read the fault codes if they're changing the belt as part of an inspection service. They might suck their teeth a bit if they discover you have a remap, but they'd have no reason / justification for wiping it AIUI...
HTH
The dealer's diagnostic tool cant delete the remap. Its more than just an on/off switch.
Thanks for the help guys just want the work done and get the cr back the same as i took it in there, well + new cambelt and warterpump
It can overwrite it.
So how can i get my cambelt changed without having to worry about my remap changing or dissapearing
You tell them there is a remap
you ask them if they have a problem with servicing a remapped car
you tell them not to overwrite it
you make them understand that if they have any problem with the above, you take your car and your pennies elsewhere.
Although a remap messes with the software and they might suck their teeth, it remains your property
