fault help and advice
Hello guys
I posted these details in another section by mistake I think. I'm a newbie to d.i.y and I have the engine management light on my skoda 4 x 4 1.8T. I took it in to skoda and they said it was a leak in the vacuum hose, but at the time they were too busy to locate the problem. They reset the fault and let me be on my way.
I've since got vagcom and have taken these readings:-
VAG-COM Version: Release 409.1-S
Chassis Type: 1U - Skoda Octavia
Scan: 01,02,03,08,15,17,19,35,46,56
Address 01: Engine
Controller: 06A 906 032 HJ
Component: 1.8L R4/5VT 0002
Coding: 10700
Shop #: WSC 31480
TMBSL21UX28540845 SKZ7Z0A1023982
3 Faults Found:
17544 - Fuel Trim: Bank 1 (Add): System too Lean
P1136 - 35-00 - -
17608 - Boost Pressure Control Valve (N249): Mechanical Malfunction
P1200 - 35-00 - -
17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
P1297 - 35-10 - - - Intermittent
Readiness: 0000 1001
Address 03: ABS Brakes
Controller: 1C0 907 379 F
Component: ESP ALLRAD MK60 0104
Coding: 0023174
Shop #: WSC 31480
No fault code found.
Address 08: Auto HVAC
Controller: 1U1 907 044 A
Component: CLIMATRONIC C 2.0.0
Coding: 01000
Shop #: WSC 31480
Skipping Address 15-Airbags
Address 17: Instruments
Controller: 1U0 920 911 B
Component: KOMBI+WEGFAHRSP VDO V03
Coding: 23412
Shop #: WSC 07893
Address 19: CAN Gateway
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 31480
Address 46: Central Conv.
Controller: 1C0 959 799 B
Component: 3Y Komfortger
The 17608 and 17705 sound like a faulty diverter valve (DV). I had the same go on mine, and I understand it's quite common for them to fail. I got a new one from VAG Parts for about
will thanks ever so much. this sounds spot on - I'm getting the whistling + the spluttering changing gear. Did this improve on performance when you got it sorted?
Thanks again
Phil
is the DV the N75 valve?
nope the N75 it just next to it afaik its the one with a cable going into it
No, the N75 controls the wastegate. I got very confused when I first started looking into this but when I eventually got it clear in my head, I posted my conclusions here.
You can find a picture of the DV by going to vagparts, "entering the shop" and searching for "dv 710n" (without the quotes). The second and third items (both the same part under different labels) are the ones you want. There is also a third connection that you can't see in the picture - it's on the top/left surface - where a thin vacuum line is connected. This vacuum line is pointing upwards when the DV is installed in the car.
I haven't noticed an improvement in performance, but the fluttering has stopped and I think this must be good news for the turbo.
i stand corrected. good read there.
Hi again
I ordered and replaced the dump valve and everything was ok for 3 days. I then filled up with super and the engine management light has come on again. could I have busted the diaphragm on the new valve just by going super? There's a cheap aluminium valve on ebay I might consider as this will eliminate any pressure issues. I bought this car 12 months ago, so don't know if it has been remapped or not. i'd have expected a replacement dump valve though. how can I check this with VAG?
I'm not really qualified to say, but I can't imagine the diaphragm could have been broken by using a different type of fuel, remapped or not. You could always test the new valve by sucking on the vacuum line, as I described in my first reply. My money's on a different fault - see what fault code VAG COM reports.
vacuum leak from the breather hose to the rifgt of the dipstick (as you look at it), carefully move it with the engine running and listen for the hiss.
Hello
sorry for the delay posting back. I got 2 error codes and now just at the last minute a MAF error has appeared.
Control Module Part Number: 06A 906 032 HJ
Component and/or Version: 1.8L R4/5VT 0002
Software Coding: 10700
Work Shop Code: WSC 31480
Additional Info: TMBSL21UX28540845 SKZ7Z0A1023982
3 Faults Found:
P1136 - 35-00 - -
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-00 - -
hi all ive fitted a k and n induction kit and a bailey atmospheric dump valve on my octavia. the other day it just died and went into limp mode ive purhased a code reader and it comes up with codes 17608 17705 17743 reading up these sound like the dump valve causing proplems any one offer advice on this, thanks jason
