[GUIDE] Activated Android Auto + Apple CarPlay on MIB2 Technisat for €0 (No dealer, no paid codes)
After two days of rabbit holes, I finally managed to activate both Android Auto and Apple CarPlay on my MIB2 for €0. Along the way I hit several obstacles that aren’t clearly explained anywhere online, so I’m sharing what worked for me.
Disclaimer
I’m not a technician. This is based on personal testing. Proceed at your own risk and make backups where possible.
My setup
  • MIB2 Technisat (MST2… ending with “T”)
  • SD card slot available (glovebox)
  • Green Engineering Menu accessible
  • OBD2 adapter (Carista; any reliable ELM327 v1.4 should work)
A lot of guides are incomplete or assume different hardware. I consolidated the bits that actually mattered on my unit, including the parts that commonly trip people up (GEM version, Toolbox structure, patch selection).
Steps I followed
  1. Confirm compatibility: Software train starts with MST2 and ends with T (Technisat).
  2. Enable Green Engineering Menu (GEM): Via adaptations and OBD app.
  3. Prepare SD card: FAT32, copy MIB toolbox to root. If GEM < 4, copy the cpu folder from toolbox/gem/ to SD root as instructed.
  4. Install Toolbox via Software Update: Run update from the head unit; expect 2–3 reboots.
  5. Run the patch: In GEM → mibstd2_toolbox → Tools → select “Patch tsd.mibstd2.system.swap and generate EL.”
  6. Toggle features: In adaptations, activate Google GAL and Apple DIO (if not already active).
  7. Reboot and verify: Check MirrorLink menu; Android Auto and Apple CarPlay icons should appear. Use a compatible cable.
Common snags I hit (and fixes)
  • GEM version below 4: Needs the extra cpu folder copied as above.
  • Single SD slot: Temporarily remove the maps card.
  • Toolbox not detected: Reformat SD (FAT32), re-copy files, ensure correct directory structure.
  • Adapter issues: Make sure your OBD2 dongle truly supports ELM327 v1.4.
VIDEO:
https://www.youtube.com/watch?v=JOUWVIDEOID
You have Navigation unit,correct?
Yes
and that is a prerequisite for this solution to work
  • 10 months later...
Video Link doesn't seem to work. Could u re-upload? The whole smartlink activation situation feels like such a scam wherr I live. 400+ to activate it... Id love to find a way to make it work myself
https://youtu.be/FoQA1dTqvRg?is=Lo_wHGVGoHSF6Ydh
Thank you so much! Fellow Dutch speaker it seems from the vid haha. Lifesaver! Does stuff like this void warranty? Still got a year on mine so should I wait a year?
Klopt! En ik vermoed zelf van niet. Worst case doen ze een update van je MIB en overschrijven ze de boel. Dan moet je gewoon het gehele proces opnieuw doen. Het is maar een vermoeden dus als je nog garantie hebt en je wil het risico niet lopen, zou ik nog effe wachten 😄
Dankuwel! Ik denk dak even wacht en het dan probeer😅
Hi, are you still active here or on the YouTube video? I am looking for a way to connect with you.
What you need?
15 hours ago, Cairus said:
What you need?
I want to understand the following things:
  1. I have a unit that has SW train starting with MST2… and ending with …T. The unit however doesn’t have NAV, and has a single SD card slot. Will this solution still work for me?
  2. Which OBD tool was used in video, can you suggest one that already worked for this specific project for you?
  3. What happens if the process fails in between in some step, if the unit soft-bricks or some other issue comes? Is there a way to go back to the original existing configuration?
No, SD Card Solution work Only by Navi
