Fault codes 16684 and 16687
Hey Guys,
problem with the VRS on the way home last night.
Limped home and got:
16684 - Random/Multiple Cylinder Misfire Detected
and
16687 - Cylinder 3 Misfire Detected
Can't get the guy I know on the phone.
Am I right in thinking it's probably a coil pack gone on Cylinder 3?
It's the Random/Multiple Cylinder Misfire Detected that has be a bit worried.
Also, with that fault, what sort of mileage will start doing it damage?
I'm 20 miles away from the garage I know. That going to feck up my CAT or anything?
thanks,
Stephenc
Is there a strong smell of petrol outside the car when it is idleing? I had a coil pack go once, and it gave off a strong smell of petrol, and the engine was rocking around the engine bay a bit.
If you have breakdown cover, get it towed to the garage - this will prevent any cat damage. It might be fine to drive, but I wouldn't want to be the one to tell you to do that.
I checked the fault codes with Ross Tech:
16684/P0300/000768 - Ross-Tech Wiki
16687/P0303/000771 - Ross-Tech Wiki
Hey,
I did get the smell of petrol on the way home alright, like a sulphurish smell.
I might swap out the coil pack myself - found some decent posts on it.
If the coil pack doesn't do it, I'll get it towed to a garage,
The Random misfire thing had me worried for a while, but as the coil pack is not uncommon, I'll try that first and see if it helps,
thanks,
Stephen.
