Mod no1 Sun-Glasses Holder
Ok, this is my first mod and I completed it on the sunniest day of the year.
I bought a VAG sun glasses holder for approx
1363.attach
1364.attach
Nice one Des :thumbup:!
I really miss the sunglass holder that I had in the Laguna, so I might follow suit...
  • 3 months later...
Do you have the VAG part number Des?
Part no is 1j0 857 465 y20 or it could be WAB/03 - 278612. There are two numbers on the box.
Bought mine from VAGParts.
Des
Thanx Des. I assume it bolts into the holes left behind when the grab handle is removed?
Des
It's the first one: 1J0 857 465 Y20
Yes, but use the original screws from your grab handle. The chrome catch and carpet sytlee lining and needs to be removed for painting but it is very sticky so be careful when re-applying it.
Des
  • 5 months later...
Yes' date=' but use the original screws from your grab handle. The chrome catch and carpet sytlee lining and needs to be removed for painting but it is very sticky so be careful when re-applying it.
Des[/quote']
Des, when fitting this, did you clip the two parts back together first then screw them on, or did you screw it on then clip the lid onto the base?
Des' date=' when fitting this, did you clip the two parts back together first then screw them on, or did you screw it on then clip the lid onto the base?
Cheers[/quote']
Trial the fitting before you paint it, it might save any possible problems.
Everything is re-fitted, the lining and the chrome catch then I screwed it in position.
Des
Trial the fitting before you paint it' date=' it might save any possible problems.
[/quote']
Whoops :o
I did this mod a while ago; but on my Octy so no problems with colour etc and yes it does just screw straight into the grab handle, but
1). Almost impossible to use safely when driving
2). I bought mine off eBay for
