Feli Pickup Suspension parts
are there some sport shock absorbers for my felicia pickup 1.3lx '96
i beleve that front are the same as in normal felicia but back are diferent
and what sport / shorter / harder springs fit on the back, from what other car? the same for the front
i read that back springs fit from golf mk4, if i want to lower the car do i need to buy shorter springs for the golf or are the standard golf springs shorter than my original? or are they the same length/height?
also i found: ''on the pick up you have the stiffest dampers of the lot.'' so if my car's rear end is soft.. does that mean that my shock absorbers are very baD?
you'll be wanting mk4 lowering springs for the back.
and iirc, the pick-up has the highest damping rate of the lot. this means the back should be slower, unless they fit stiffer springs to, then they would match the higher damping rate.
