How do I find the PR number?
I've done a search but all I keep coming up with is the engine and VIN numbers etc. :(
VAGCAT seems to need the PR number and so do GSF I've found in certain cirumstances. The latter mentioned it may be on the sticker in the boot......I looked, found lots of numbers but nothing resembling a 'PR' code. :confused:
Any ideas folks?
Many thanks,
Chris.
Any ideas folks?
Many thanks,
Chris.
The pr number is the code for the suspension setup. HAng on a min i have the pr number for the vrs somewhere
John, stop being so bloody helpful, it's getting silly now. :D
Well, stop after you've given me the PR code anyway.....
Chris, the PR number for the vrs is either PR-1LN or PR-1ZH. To be 100% accurate, i need to order of the coloured blobs from one of the rear coil springs.
If Your not in a rush ring dm keith wakefield and ask for philip on parts, if you give him your chassis number he should be able to give you the part number you need or the PR number. ;)
Sorry :o I try my best in future :rofl:
Outstanding. :D
Thanks again buddy.
You've no idea which steering box section would apply to my car have you?
Fabia 2004
EDIT: Think it may be 1NL - if it's the one in the huge long list of options codes on that sticker in the boot.
Just found this lol...
VW Group Option Codes Decoder
Really useful....was in the tech guides section. :D
Hmm, an interesting, if poverty level spec:
E0A = no special edition
1D0 = without towing attachment
5SJ = outer left rear view mirror: convex
5RV = outer right rear view mirror: non-spherical
1KP = disc brakes, rear
6FB = body-colored outer rear view mirror housings
1AP = anti-spin regulation (ASR) with electronic differential lock (EDL), lightweight design
3FA = without roof insert (standard roof)
1N2 = power steering electro-hydraulic
1NL = covers for alloy wheels
H2J = tires 205/45 R 16 83W
4UE = airbag for driver and front seat passenger
4R2 = power windows front, mechanical window regulators rear
3NC = rear seat bench/backrest, split folding
3QT = 3-point seat belts with tensioner and height adjustment, front
4X0 = without side airbag
4A0 = without seat heater
8L3 = roof antenna
J0L = battery 340 A (70 Ah)
7AH = electronic vehicle immobilization devicewith alarm system, passenger compartmentcontrol and backup horn
8GD = alternator 90A
6Y0 = without cruise control warning system
9AP = semi-automatic air conditioning
8RM = eight loudspeakers (passive)
7Q0 = without navigation device
8UE = radio with CD drive
8QL = key for locking system with remote control
8X0 = without headlight washer system
4K3 = radio remote controlled central locking operated from inside and safe securing
B09 = type approval Great Britain and NorthernIreland
G04 = front shock absorption
QN1 = drawer under left front seat
3L2 = manual height adjustment for right front seat
9P0 = without seat belt warning light
Q4H = comfort sports seats, front
7X0 = without park distance control
9W0 = without car phone preparation/installation
BWR = code not found :-(
7A0 = without CD changer/CD player
QG0 = without service interval prolongation
0GZ = emissions concept EU 3
L35 = suspension range 35
7P0 = without lumbar support in front and rear seats
FDA = code not found :-(
3S4 = preparation for roof load rack
Outstanding. :D
Thanks again buddy.
Fabia 2004
1nl stands for alloy wheel bolt covers tho:confused:, the number PR-1LN and PR-1ZH i gave you are listed for both azl and asz engines.
After looking at though 1NO rings a bell for some reason...... I have it written down somewhere in my folder of notes on the fabia. Just Cant find them :thumbdwn:
Gunner have to sleep now tho, were off to newcastle tomorrow on " buisness" :rofl: will be back monday :D If you not sorted it by then mate, ill give philip a ring, i need some bits myself.
____
john
Ah yes, good point. :D
Thanks for your help anyway mate. Just trying to figure out a bit more about the rack and stuff, and which diagram would be applicable to my car. ;)
Good luck with the 'business'.....make sure you take enough muscle with you to avoid any 'misunderstandings'. :D
